Loaded, won’t run
Washer originally filled with water @ beginning of wash cycle, then just stopped. Won’t spin, but if turned to rinse, will run more water in. What’s wrong with it? HELP PLEASE!!!!
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
1 Comment
Thanks so very much. Was definitely the problem, got the part and working perfect.
by greer1410
