Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Can I fix my display affected by drowning in water?
My iPhone 3G got drowned in water for a few seconds. I immediately switched it Off.Then I tried to dry it by blowing in the docking connector area. it kept on turning On & Off automatically for some time. I opened the front cover (thanx to iFixit!)and there was not much damage. not much water trapped. However the LCD top right part is affected.(see images here ) the touch works but it looks like the water is spreading in nearby areas on LCD.
Shall i wait before i switch it On again? is my Display damaged permanently? what should i do? HELP needed urgently !!
Add a comment
Chosen Solution
if you look at this guide you'll see a LCD that looks's not, it just needs a wipe to remove the watermark. If you can see a water mark on the LCD then it is likely you have "watermarks" on your internal components...water isn't just the liquid, it's the minerals too. So drying doesn't stop the damage from slowly eating your components... it's up to you. Repairing iPhone Liquid Damage
Score 2
Thanx a tonn scott & polly,
i could actually use your advice and my iPHone is perfectly fine now.
I kept it in a jar with dry rice for 2-3 days and then switched it on. It worked fine.
Even the LCD watermarks has gone completely.
Thanx Again
Great job Amogh, all you have left to do is now to Accept the Answer that helped the most, This way people that are looking for answers will see what works. Good Luck and Great Job.
Add a comment
Water damage is tricky, but if you are saying that the phone is working aside from the LCD, replacing just the LCD may solve it. You want to make sure it is completely dry before you turn it on. Don't mess with it until it is 100% dry.
iPhone 3G Display
Score 1
Add a comment
Add your answer
amogh chaugule will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 4,695
