Battery Doesn't Calibrate After Replacement
As in the title, this doesn’t seem to work, according to coconutBattery the full charge capacity is 4752mAh, and the design capacity is @ 72% of 6600mAh. BUT it lasts for hours from 7% charge, goes down pretty quickly before that however.
I’ve tried:
- Charge until full, then 2hrs more, then completely deplete and leave for at least 5hrs in sleep mode. Then recharge to full - which I left charging for over 12hrs. No change
- After this I reset the SMC and tried the same procedure, still no change in it.
Any possible solutions ? Could be a faulty SMC perhaps ? I did see some sticky gunk inside when changing the battery, looks like something was probably spilt on it at some point..
*Edit* coconutBattery Screenshots:
2 Comments
Can you post the CoconutBattery main window with the MagSafe connected and again with it disconnected Adding images to an existing question
by Dan
Added, thanks
by Javier Romero
