Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
Water damage ... Errormessage there's not original accessory attached
Hi, i got an iPhone 3Gs which has fallen into water ... two days later it worked very well, but sometime there get up this errormessage that it is not original accessory attached ... after that the normal speaker doesn't work ... after the next errorpopup the speakerfunction get back ... cleaning the connectorport with a brush didn't helped really ...
what can i do to get this errormessage away?
is it only oxidation and I've to open and clean everything from it?
thnx a lot!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Clean the dock port pins which are on top of the mib rid very thoroughly with isopropyll alcohol.
Score 1
Add a comment
Most Helpful Answer
synth, check on here. this usually works pretty good when you are dealing with this kind of dilemma Electronics Water Damage Good Luck and let us know how it is going.
Score 2
Add a comment
Ok, it's long time ago, but here's an answer ...
haven'n done anything, after updating to newer iOS-Version and Jailbreak the error was gone and the device worked very well! ;)
Add a comment
Add your answer
synth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 620
