Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2688 Questions View all
iPhone 6s | Ribon Cable has been cut
While I was replacing the battery, the connecting black ribbon has been cut. I think it was for the front camera and the speaker. You can see from the photos.
Is that enough to replace the front camera/speaker?
Add a comment
Chosen Solution
do you mean cable or ribbon, if you mean the cable that goes from the charge flex then no you will need to buy a new charge port, any of the ribbons are sold seperately
Score 2
Add a comment
There may be someone selling this cable, however the upfront equipment and process cost needed to replace the cable alone will exceed the cost of the phone, therefore it is not economical to buy just one cable unless you are refurbishing screens commercially.
Score 2
Add a comment
Remove the camera & speaker flex. It looks like it could be that one.
As the smaller one is for the home button, and the other one which isn't cut, I think is for the LCD.
If that part of the cable is from the camera flex, then you need a new front camera.
If it's not, then you'll need a new LCD.
You won't be changing the LCD flex without any proffesional refurbing kit.
Score 1
1 Comment:
Dear Duane,
I have added a new photo after removing the camera and speaker. It seems the ribon is for the camera.
Is the phone running without (unplugged) camera and speaker?
by
Add a comment
Dear Daniel,
Thanks for your reply.
I think it is ribbon, please find the below screen shot.
I found some parts on the spare parts categories. Is the below link is it for my problem?
iPhone 6s Test Cable for LCD Screen and Digitizer
iPhone 6s Test Cable for LCD Screen and Digitizer Image
Product
$14.99
2 Comments:
it could be an lcd ribbon in that case which means you may need a new screen otherwise it could be to do with the front camera/speaker or home button ribbon
by
The front camera ribbon cable needs to be replaced. That is torn in the picture you've shown. Screen cables are OK
by
Add a comment
Add your answer
nzmturkan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 513
