These parts are damaged on my logic board (PICTURE)
After looking it over carefully i figured out that the two little chips circled are broke off and the yellow line in the top left corner is cracked just like i drew so the top green layer is pulled up. What are the two chips for? and is one of these damages whats causing the board not to work?
14 Comments
its hard to say actually with that picture i showed above because its different from mine this board is exactly the same and it shows the exact two that are broke on mine what are these?
[image|110089|size=thumbnail]
by Jared
actually nevermind oldturkey its the same ones you were right thank you. now how do i find these exact chips on digikey
by Jared
What you can do is take a look at the schematic I linked to earlier. Find the C248 and C250 The schematic will have the value of the capacitors. With that information, take a look at mouser.com or digikey.com and look for the SMD capacitors... It is tedious to find it on the schematic, so don't get to frustrated...;-)
by oldturkey03
do you think you could help me find the value im having a hard time
by Jared
ok i think i found em there right next to each other and they read 27pF in red below them. Do you know how big the case size is of them?
by Jared
Show 9 more comments
