MacBook Air won’t turn on after keyboard replacement
I just replaced the keyboard on a MacBook Air A1466 and now it will not power on. The MagSafe charger does not light up when connected. I’ve triple checked all the connections and all the ribbon cables and everything is as it should be.
Now if I remove the I/O cable the MacBook turns on and the indicator on screen shows that it is charging even though the charger still doesn’t light up. A message pops up on the screen that no keyboard is connected and neither the keyboard nor the trackpad works. However the new backlight that I installed does illuminate. When I reconnect the I/O cable the MacBook shuts off.
As I've said I checked the keyboard ribbon cable connection. Any help would be appreciated. Thanks
