Is my heat sink broken?
MacBook Pro 15" Retina Display Mid 2012 is getting really hot!!
In MacOS while watching YouTube or Netflix in Safari the temperature would reach 75c-87c in comparison the Late 2013 model 40c-70c, idle temperature is at 70c-80c while late 2013 model is at 40c-55c.
In BootCamp I would get lag stutter in CS:go with 100fps+ spiking down to 30fps every seconds or so. Also, I open up the MacBook to touch the heat sink the late 2013 model is really hot in the fan side of heat sink with fins as well the CPU and GPU when gaming while in the mid 2012 model is really exceptionally hot at the CPU and GPU but is cool or warm with ability to touch for 5-10 sec without issues at the Fan area with CPU temp at 90c but in the very far side of the edge of the heat sink it is cool, touching the CPU and GPU area would show really hot with instant release needed.
I have cleaned the fans and changed the thermal paste already.
idle
Full menu
Image taken without safari closed & cold start
(activities: open safari)
conformation fan is working and youtube in on safari in a tab with music full rpm fan @ 60c
floats around 70c-85c with image on display, without display of safari tab of youtube 64c-74c
5 Comments
How about posting a snapshot of TG Pro main window showing all of the sensors and fans here so we can see more clearly whats going on. Adding images to an existing question
by Dan
done as requested
by Jason lieu
Can you give us the Show Main Window view Vs the Pull Down view. You'll find the option in the pull down at the bottom. If offers the Fan RPM at this point they don't appear to be running!
by Dan
the fan does ramp up only when @ 90c for a period for cpu, smc and pram has been reset as well. I has Mac fan control set up at full rpm @ 70+ the fan is at this when I'm watching youtube/netflix
by Jason lieu
Trash MacFan Control! It overrides the SMC services so the set point is it On/Off no variability! Not a good app!
I've seen so many systems cooked with it! Apple does a good job with SMC services it's only when we push the system beyond what its designed to do it will fail.
Here while you are pushing your system MacFanControl is just getting in the way. TG Pro is so much better but it does cost a bit more than free for the full product.
by Dan
