Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1418 Questions View all
Computer will only run on battery, not with power adapter.
Not sure what to do with this one! The computer works 100% fine on a battery, however with AC adapter it wont start up at all nor will it charge the battery. The magsafe is bright green like the computer does not need to charge or no battery installed, and when i have both a charged battery AND the magsafe on with the computer running, it says its running off the power adapter (but its not, i disconnected the battery and it shut off). Soooo any ideas? I replaced the battery connector and the magsafe board with what i thought were known working components and nothing, so I might try another magsafe board just ot be sure. Unless anyone has any other thoughts? Thanks in advance.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
I'd go for a new mag-safe board from a source with a good reputation even though it may cost more.
MacBook MagSafe DC-In Board
Score 2
Comments:
i will try that, i thought the one i had worked but have no true verification. i know i get the same result with both though (magsafe turns green but doesnt charge laptop!)
by
removed the logic board yesterday, its perfectly clean inside and out, put everything back and same issue. will try a 3rd DC in board today, then its going on ebay!
by
Add a comment
I'm having the same problem... let me know if you find anything else out. I replaced my MagSafe DC-in and then thought about replacing the battery connector but that may be a waste of time.
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,002
