Will not wake when opening lid
Hi,
My MacBook Pro will not wake up when opening the lid, it keeps thinking that it is still in clamshell mode.
When connecting an external display it works but when removing the external display it will not revert back to the internal display.
Also, when shutting down and I close the lid I cannot turn the device on, but when shutting down with the lid open it works as intended, I tried running a magnet near the left side thunderbolt ports sure enough the screen turns off and will not turn on.
An SMC reset does fix the problem but I dont think I can do an SMC reset every time I close the lid of my laptop.
Is this a magnet sensor fault for the lid?
Update (01/31/2019)
Update: It happened again. I’ve changed all my power outlets as well. What is causing this?
3 Comments
Bring your system back to Apple as it should be covered under the repair warranty.
What are you using to charge your system the original Apple charger as well as the USB-C cable that came with it, or are you using something else, or using a Hub.
by Dan
Yes apple is repairing it again but this would be the 3rd time they will repair the computer, at this point I don't know what I'm doing wrong, I've been using the same charger and cable that came with it, the laptop lives on a desk so I have no clue anymore why its always breaking down.
by louiechua2006
It's not you, this is likely a quality issue with the rebuilt part
by Dan
