Swapping out the bottom case
Mates,
I'm using the step-by-step guide to swap out the bottom case on a macbook pro this weekend. The guide states that one of the tools required is a "4mm nut driver."
However - nowhere in the guide can I find the step where this tool is used. I don't have this tool, and can't get it in time for this weekend...
Has anyone else followed this guide? Do you know which step it is required in? Do I really need to have the "nut driver" for this project?
Thanks for all your help.
Armen
Add a comment
Chosen Solution
I don't remember ever seeing a 4 mm nut on this machine. It might have one at the very bottom but a pair of small needle nosed pliers would most likely work.
Score 3
Add a comment
There is a 4mm standoff that attaches the left I/O board to the case. I successfully used needle nosed pliers to remove it.
MacBook Pro 15" Core Duo Model A1150 Lower Case Replacement step 44
Add a comment
Add your answer
armen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 571
