After screen replacement the 7 Plus turns off itself
I just did a iphone 7Plus screen replacement. I turn off the phone and disconnected the battery and did all the process as always.
But when I turned on the phone the battery was on 1% but the phone has battery. When I put the charger, shows back 67% battery.
And the phone shut down by itself.
Turn off and turn on by itself.
Everything else works fine.
I searched on some forums and someone said that it’s the front camera problem, just replace it and it will resolve the problem.
Someone else said it’s the IC cover that is on the lcd is exposing some of the micro caps which is touching the LCD shield when you install the screen. Those caps ground on the LCD shield causing the LCD display to either shut down, over heat or make the display look like its fading out.
Another person said just connected to iTunes and do the restore.
And someone said could be gas gauge problem.
Anyone that has this problem before?
Could it be logicboard problem or something else?
