Symptom of drive failure? (Fusion drive, iMac)
Hello.
I have a late 2013 27” iMac - 14,2 - 3.5GHz - … EMC is 2639 … 3TB internal fusion drive.
The overall system performance when using this internal drive as the startup is very bad.
However, duplicating a large file (like 100GB) on this internal drive to itself seems pretty fast.
But, copying that same file to a decent external drive is incredibly slow (the finder says it will take ~3 days to copy that 100GB file to an external drive). Is that still symptomatic of a failing drive itself, or something else in the file system/file hardware?
(I wouldn’t want to install a new SSD drive, only to have the problem be something else.)
Thanks.
-Allan
Update (12/11/2018)
From the system report, here's the INTERNAL Apple drive:
Available: 1.47 TB (1,469,475,217,408 bytes)
Capacity: 3.12 TB (3,121,506,295,808 bytes)
Mount Point: /Volumes/Macintosh HD
- File System: APFS
- Writable: Yes
- Ignore Ownership: No
- BSD Name: disk2s1
- Volume UUID: FBDF963E-B821-3C1A-9039-4032684E3CF3
Physical Drive:
Device Name: APPLE SSD SD0128F
- Media Name: AppleAPFSMedia
- Medium Type: SSD
- Protocol: PCI
- Internal: Yes
- Partition Map Type: Unknown
- S.M.A.R.T. Status: Verified
...and here's the EXTERNAL LaCie:
Available: 3.91 TB (3,906,058,018,816 bytes)
Capacity: 4 TB (4,000,577,273,856 bytes)
Mount Point: /
- File System: APFS
- Writable: Yes
- BSD Name: disk4s1
- Volume UUID: 4E6B39CB-90B3-3448-ABBB-1CA5A9FE4959
Physical Drive:
Device Name: Rugged USB-C
- Protocol: USB
- Internal: No
4 Comments
Are both drives Apple original? Have you upgraded to High Sierra or Mojave and did this slow down occur after that? Do you have Microsoft Office 2011 installed?
by mayer
The internal is Apple original. I've tried two of the orange LaCie externals (usb and thunderbolt, both the same performance when copying). OS is High Sierra, but it had been working well for quite a while with High Sierra. Office 365 installed.
About 4 days ago, the performance all of a sudden became quite bad. That said, over the past year, I've been beachball-ing more and more.
With the LaCie external set as the startup disk, the system performs well.
by lagouyn
Are both internal drives Apple originals?
by mayer
There is only one internal drive (Apple original). Duplicating a file to the same drive seemed to be fast. But copying from the internal to an external is the thing that's super slow.
by lagouyn
