Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Battery Recognised & Status Good, but won't charge
Have a nice MacbookPro9,2 i7 that I bought new - never been dropped, damaged, exposed to liquid, etc.
Recently changed out the existing internal HD for an SSD. I’m very careful in disassembly/assembly - use an ESD mat and strap, etc.
Upon reassembly the machine will only run when connected to a power supply- remove the supply and it shuts off instantly.
Passes all AHT diagnostics.
CoconutBattery recognises the battery, lists the status as Good, failure as None, Cycle count as 921 (close to EOL but was charging fine before). Current charge and capacity are all 0. Charging wattage lists as 0 W, although every now and then it will jump up to a very low value like 0.08 W.
Magsafe light is always on green (never orange). When computer is off but connected to power the Magsafe light is green but flickers ever so slightly. Battery charge indicator lights always show full power (even when Magsafe disconnected - indicating either battery is actually charged or perhaps there’s a capacitor in there).
Tried resetting SMC and PRAM, along with every permutation of disconnecting battery, disconnecting charge indicator lights and resetting. Cleaned Magsafe connector, tried several different power supplies.
Inspection of battery and exposed parts of logic board appear fine - have not pulled it down further.
Add a comment
1 Answer
Chosen Solution
Try unplugging battery from the logic board and see if that Magsafe light flickering disappears. It might be the battery, but the fact you have that flickering and Coconut status shows Good would make me a bit cautious about investing on a battery replacement.
Score 3
5 Comments:
thanks - think I tried that already but now I can't remember that the status of the Magsafe light was, so will try again.
by
@tunecrew You're welcome..if you have a multimeter at hand we could at least have some basic testing on battery connector pins. Maybe not decisive to a perfect diagnose but it would be a start.
by
@arbaman yes I do - is there a pinout of the battery available anywhere?
by
@tunecrew You don't really need a diagram for charging basic tests..from left to right you have pin 1,2,3 showing 12.5v, pin 4 - 3,4v pulsing, pin 5 no voltage, pin 6 - 3,4v pulsing, pin 7,8,9 ground
by
@arbaman thanks gonna check those voltages!
by
Add a comment
Add your answer
Christopher Edmonds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
