Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
The User Manual (which you can get online) recommends:
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 41
All Time: 1,692
1 Comment
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
by Johannah Rodgers
