After screen change the top part of the screen is not touch responding
After screen change the top part of the screen is not touch responding, but the rest of the screen works fine.
You will need to double check the connections to eliminate that as a possibility. Otherwise, it’s probably just a defective screen. You can confirm this by re-installing your original screen, assuming it was somewhat functional, to see if the touch responds well on that. Contact your supplier if the screen appears to be the issue.
I did check it a few times. I will try it with some other screen as well, just to make sure the conectors on the phone are ok. Thank you for your answer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 36
