Lint and dust under the LCD
When I use my phone outside in sunlight I can see what looks like white speaks of dust under the LCD screen. Is there an easy way to get rid of it? Anyone else have this issue?
it's easy. power the phone off using slide to power off then follow the guide on the right for replacing the lcd. you'll need a suction cup and a size 00 and a 000 for getting the screws off the sides of the midframe to release your lcd. take your time, read the guide and make yourself familiar with the steps before you start...it'll make it a whole lot easier than reading as you go. should only take about 10 minutes! use a lintfree cloth and gentle pressure to dust it (like cleaning glasses) reassembling the display onto the motherboard connectors is a bit tricky... but again, take your time, be patient!! no.3 doesn't slide all the way to the white line on the flex, just slide in until you feel resistance then close the locking tab.
good luck
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 726
