If you replaced your battery and it is still not charging or holding charge properly, most likely you have a faulty Charger, charging cable, charging port or charging IC is bad. Using a multimeter, measure the voltage on the logic board side battery connector while it is plugged in and test if it is receiving a charging voltage or not. In a majority of cases, it seems that Tristar goes bad or Tigris goes bad and needs a new IC chip to work again. You could always charge a battery up and then try it to see if it powers on and works properly to verify this without a multimeter
