The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Questions View all
What's wrong with my display?
I bought a used Macbook Air earlier this year. When I first got it, the screen would sometimes glitch, which was no big deal. But over time, the started to display fade out to blue with vertical lines and I couldn’t see the display. Now, the only way to properly see the display is to hold or twist the screen a certain way or put pressure on the back lid. Sometimes (rarely) I don’t have to manipulate the screen and the laptop works fine. Could this be a connector issue?
2 Comments
Can you post some pics so we can see whats happening Adding images to an existing question
by
If you have to move the screen for it to display properly then the LVDS cable is probably damaged.
by
Add a comment
1 Answer
Chosen Solution
Probably the lvds cables are not in a good condition or may be the connection to the cables are loose
Make sure the cable connections are proper.
If still you are facing the issue you have to order a new LVD cable and fix it.
Add a comment
Add your answer
kcatelin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
