The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
System starts, but nothing appears on screen.
I was playing a game when the sound got very degraded and starting a "clicking" noise in game. The system sounds fine. After reseting the system I was playing again. Everything seemed fine then a while later it froze with green dots/lines on the screen. I shut the system down from the switch in the back because the system wouldn't respond to the front power button. After this there is no longer any picture or sound. I have tried the video reset by holding the power button down. My controllers also no longer connect to the system after I tried the reset. Any idea what this could be and if it could be fixed without the manufacturer?
Add a comment
1 Answer
Chosen Solution
If you have the option to send this in for warranty, I would absolutely take advantage of that since the fix is not terribly fun to do. The one I hope you only have to do is a soft reset of the video which involves you holding the power button for 8 seconds or until you here the beeps after the initial power beep. This will power on the system and after you hear the beeps you let go and it will have reset the video to factory defaults. From there select the appropriate video setting for your television and while you are at it get a can of air and try to clean the dust out from the fan on the bottom and make sure there is good air flow from the back of the system. If you are able to do this do not continue to read this answer.
You are still reading? Well thats a shame because it seems like this a problem with the GPU thinking that it is constantly overheating and shuts itself off to prevent any further damage. The only option you have is to disassemble the system and overheat the GPU and surrounding memory chips to try to get the GPU to reset itself. The article for the YLOD fix applies to this solution and is very good, but as a personal note, DO NOT move the board during and 10 minutes after using the heat gun or you could permanently damage the motherboard, and a replacement motherboard should not be purchase as it is married to the blu-ray drive so if either are swapped without spoofing then you will no longer be able to read any disks.
I have included the link to the repair guide here.
As a side note, it is important to maintain good air flow after repairing the device. If you do not then you might have to do this repair again in a month or two.
Score 2
1 Comment:
I was amazed when i opened our PS3 just how much dust had accumulated in and around all the parts. It's worth getting a big paintbrush out and giving everything a very good clean...
by
Add a comment
Add your answer
Jonathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 882
