iMac Intel 27". EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz), EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz)
357 Questions View all
Does the logic board have 1 or 2 SATA ports?
Does the logic board for Apple Part #: 661-5319, iMac 27" Late 2009, 3.06GHz, Core 2 Duo, have 1 or 2 SATA ports.
Would like to add an additional SSD drive so I can have the original 1TB HD and a Runcore 240GB 2.5" SSD drive at the same time.
Thanks very much
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Yes it has two... One being the HDD SATA cable, the other being the ODD's. You can take out your optical bay drive and use one of these to mount your SSD in. I personally have the same model as you (Except i7) and I just took out the HDD and put in the SSD. Put everything else in an external storage.
When I did do that, I had some fan issues (well it doesn't bother me though...) but check this out:
SSD compatibility (Thermal Sensor Connector)
Score 4
Comments:
You can use something like this to use multiple SATA ports
by
Add a comment
Add your answer
Jonathan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 16
All Time: 3,307
