Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
iPhone won´t boot properly after LCD replacement?
Hi Guys,
After replacing the LCD, my Iphone wont boot all the way to the Springboard. Symptoms: After turning on, the Apple logo appears, from time to time the spinning loading symbol appears, thats it. From researching Google I have the feeling this is not directly related to replacing the LCD. Itunes does recognise the Iphone so a restore would probably be one option but that would mean loosing all data as I havent synced recently. Is there a way of either kicking the Iphone out of this loop or saving data (partialy or completely) before restoring it.
Things Ive tried:
-Tiny Umbrella recognises the Iphone but I believe "Fix Recovery" in DFU mode will delete everything (am I wrong here?)
Thanks to the community for having a look into this!!
Cheers,
Leon
Comments:
tinyumbrella should have an option to exit recovery.. not fix recovery...?? I think it does what it says on the tin, makes the device wake up, but I don't want you to lose your data.. One of the other guys is much better at the jb questions, i hope he sees this and can help.
by
which version u r using now in iphone?? tinyumbrella helps to kick out recovery mode upto 4.1, above version of iphone not working properly on fix recovery mode option in tinyumbrella
by
Hi Guys,
first of all thanks for the quick replys!
I am using Version 3.1.2 so tinyumbrella should in theory work. It does have the option "Exit Recovery" as well as "Fix Recovery" when the Iphone is in DFU mode. However "Exit Recovery" is not available for my Iphone so I´m suspecting that it is not actually in Recovery mode, I might be wrong here! My last resort would be to Restore using iTunes and then try to extract the image file and recover what I can. This does have a lot of !#^@ up potential so I am a little scared and hoping for alternative ideas from you guys.
THX!
Leon
by
There's a recent/ new version of tinyumbrella...
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
This could work, if you know the firmware your iPhone is on currently. Download your current firmware from Apple to your computer. Download Redsn0w and then run Redsn0w. Redsn0w will not touch any files that you care about on your iPhone. If Redsn0w does not help, then you will be right where you are now. If it works great.
Score 1
Add a comment
Add your answer
Leon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,266
