4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Why is the front bottom left corner hot but only when I’m not using it
I dropped my iPhone SE in water a few days ago, but put it in rice to dry and since then it has been okay until today. Now my battery drains VERY fast and the front bottom left corner heats up a lot, to the point where I almost burned myself. It only heats up when I’m not using my phone. It happens both when it is and isn’t charging, and I’m not sure what to do. I don’t know if it’s safe to leave it by my bed at night because I fear if it’s off for so long it could heat up even more and possibly catch on fire or something. Could be a bit of a stretch, I’m just a little worried about that. When I start using my phone within 5 minutes it’s usuallly cooled down and normal. Also about the battery draining, it seems to be doing a little better now, but this morning I unplugged it at 50% because I noticed the corner was heating up. I didn’t use it so it could cool, and when I checked in 20 minutes, the battery was down to 25%. Right now it seems to be a little better, but not much.
Score 1
Add a comment
Chosen Solution
I’ll basically repeat the answer I just gave to another OP…
With water damage, you have to decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road, as you saw in this instance.
 Rice is a persistent myth, one that should be eliminated from the vernacular :>)
The water is inside the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is. So while it “may’’ soak up some water vapour, the real problem is the mineral deposits that can cause short circuits or the corrosion that is taking place as the water evaporates. Leaving the power on the device accelerates the process. The longer you let a phone sit in rice, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur. The water needs to be displaced, not evaporated.
On some phones, rice treatments appear to work. But those are phones that had minimal water ingress and not anywhere near a danger area on the logic board. They would have recovered regardless of the intervention.
 The proper way treat a wet phone is to do the following:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Score 3
Add a comment
Your having a short in the wiring
Add a comment
Add your answer
D G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,219
