LED Plus backlight TruMotion 200Hz Triple XD Engine LG Smart TV Wi-Fi Built In Picture Wizard II DivX HD Dual Play Compatible Smart Share Network... Overview Brands : LG Energy Rating : 7 Resolution : 1920 x 1080 Width (mm) : 1357.60 Height (mm) : 848.40 Depth (mm) : 331.00
37 Questions View all
Turning black for 10 seconds and turning back on. LG 60LB6100 the TV s
T
shuts black about twice every 30 minutes
Add a comment
1 Answer
Chosen Solution
Darla Robillard
intermittent failures like this are hard to diagnose. Could be an input issue, so try all different input sources (HDMI, Coax, Composite etc.) Could be a firmware issue; disconnect everything from your TV including the power board. Then hold the power button down for 15-30sec. Plug the TV back in and connect a Video source and see if that changed it. If none of this works you may have to consider that this is a power board, main board, or backlight array issue. Once the TV turns black, shine a flashlight at an angle against the screen. If you can still make out shapes and forms, you know that it is a backlight issue. If you cannot it is most likely a main board issue. Again, these errors are hard to diagnose and sometimes it may just be easier to learn to live with it.
Score 1
Add a comment
Add your answer
Darla Robillard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 27
