The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
56 Questions View all
Does not turn on ...Can you help?
Just bought Power Mac P4 and It will not come ON ......Can you suggest what I can try????
Comments:
Matt, you edited this to a Quicksilver, why?
by
Add a comment
Chosen Solution
I'm assuming you mean a PowerMac G4. Is anything happening--ie any noises, lights and so forth. We really need a little more information to properly help you. Ralph
Score 1
Add a comment
Tough one -- could be just about anything. But the last time I had a computer similar to this conk out on me (it was a B&W G3), I checked all the hard drive connections, unplugging them and replugging them. If I'm remembering correctly, I think I also swapped the PRAM battery with a PRAM battery from a different, working computer. And I may have removed and reseated the RAM. The computer eventually started back up, but I'm not certain exactly which of my various tricks brought it back.
UPDATE: You can find teardown and repair guides for some G4 PowerMacs here: Power Mac Repair
A couple of safety tips, in case you haven't opened a machine like this before -- be sure to unplug the machine before you open it up. Be sure to wear an anti-static strip and/or frequently touch metal while working on the machine to decrease the chance of static electricity frying the machine. And take special care when working inside these machines -- there are some sharp metal edges inside and you don't want to cut yourself.
Score 1
Comments:
I agree with mister790--try the things he suggest. If they fail to get you started you may have a bad power supply. Hers a URL to help you with that if needed. Ralph
Why won't it power up?
by
Add a comment
nothing no sound no light nothing wantmy phone number ? David
Add a comment
Add your answer
David Martinez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,894
