Surface Pro 4 won't turn on at all after battery replacement
Hey! So I followed the guide here on iFixit to replace my battery. Unfortunately now my Surface Pro 4 won’t turn on at all (unplugged or plugged in). Nothing happens, not even the fan goes on.
I can’t really figure out what the problem might be. Maybe someone can give me a clue where to look next or what it might be?
A few more notes:
- When I tore off the screen I broke one of the three antennas at the top, but I would guess this wouldn’t cause this problem.
- When I first tried to turn it on, I forgot to connect the fan back to the mainboard. I fixed that very shortly after.
- After it didn’t work the first time, I removed the battery again and put it back in, but that didn’t help either.
I hope that is enough information!
18 Comments
I've the same problem, I've removed the broken screen and I've cutted the antennas...but the glue is very strong!Very bad position to put an antenna.
Now I've replaced also the battery, with one compatible...but I've checked that the code is different from the original:
original model was DYNR01
current model is G3HTA027H
...and now my Surface is dead! :(
I don't know if the problem is the battery, Iìve not found a confirm of that, but i suspect that tha model should be the same of original.
Regards
Stefano
by stefano.gunella
Were you able to solve this issue? I am running exactly the same Problem!
by kevin.amaral
me too, I have had this problem several times, I put a new battery in and it will power up and charge the battery but not power up from the battery without the charger plugged in
by Ed's PCs Victoria Point
I have the same problem. Was someone Able to solve it?
by kevin.amaral
Hi People, more than one with the same problem, after change original battery. The battery in my case is the same code of original battery. Battery change maybe ok but Surface wont turn on. Anybody have the schematic board view? Thank´s
by Ricardo
Show 13 more comments
