Is perfect after two hours vertical lines showing on tv
I have sumsung 32 lcd i have a problem when i power on the tv it is perfect after two hours vertical lines showing on tv screen pls suggest what is the problem
Mohd Shakeel first you need to let us know what exact model your TV is. Then we would have to see what those lines look like. This could be an issue with the gate drivers (part of the LCD), the T-con board as well as main board. Add some pictures of what your screen shows to your question. That way we can see what you see. Adding images to an existing questionIn your case it does sound like components on the main board could be failing
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 115
