Black screen while backlight works, display data cable replaced.
I basicly have the same problems with my 2008 15" MBP (no unibody) as this question:
BLANK screen! Backlight OK, external OK. Sometimes(randomly) works?
The MBP was as first brought to a repair company, but when the laptop was there for over 2 weeks, the display worked fine and they ran all possible tests they could run without the screen turning black. When I got my MBP back from this company he indeed worked fine! For 2 months... the problems started again with as result no image at all. Only the black screen with the backlight on. (MBP runs fine on external display).
Now I knew it for sure, the Display Data Cable was broken. So now I decided to replace it myself. I bought the cable (MacBook Pro 15" (Models A1226/A1260) Display Data Cable) and replaced it.
Now the worse part, it still does not work! Is there anything else I can do to fix this? Can I turn the laptop on while it's opened? Can I run some faulty connector tests?
The MBP is an early 2008 model which still is working great on the internal parts :(
Add a comment
Chosen Solution
Hold a flashlight at an angle to the screen and when it's booted up (and hooked up to an external monitor to make sure), see if you can discern the desktop on the Mac Book.
Score 3
Comments:
Thank you for the reply.
I tried to see if there is an image when it's booted but no luck. The backlight is working fine, I can control the light intensity with the F2/F3 buttons.
It just seems that there is something wrong with the display data cable, but I have replaced it. Can I clean out the connectors? Or do some tests while the laptop is fully opened?
by
Add a comment
Any news on this item? I have a very similar problem see: Black screen while backlight works, switches to normal now and then.
Comments:
I am sorry, I don't have an solution for the problem yet. I did not have much time to try much else. If I have a solution to the problem, I will let you know :)
by
Add a comment
Add your answer
rdeklein will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 25
All Time: 3,570
