Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1408 Questions View all
Diagnosing a faulty, Inverter Cable?
Hey everybody,
I bought my macbook about 6 months ago and woked about right. A few weeks ago when i opened up the screen noticed that it when dark (just the backlight) if it was below a 90 degree angle, the problem started to get bigger and the screen would go dark on almost any position. The problem corrected if i moved a bit the angle, did a bit of research and found out it could be a faulty inverter, i replaced the inverter last week and it worked out fine for a couple of days but today i'm getting the same problem if the screen is below 90 degrees it goes dark (still only the backlight).
Been looking through other questions and i'm finding that it could possibly be the inverter CABLE not the inverter board.
Is there a way i could diagnose this?
I would really like not to spend on a replacement to find this was not the problem. (Like it happened with the inverter board)
Thanks for taking the time to read this!
Comments:
This is odd, i replaced the inverter cable, being pretty sure that was the problem, but i'm still getting the same screen-going-dark problem while the screen is on certain angles. Does anybody have any suggestions on this issue? I'll appreciate any help.
Thanks
by
Add a comment
1 Answer
Chosen Solution
If it changes when you move the screen, it's a cable. If you can sill see the desktop when it goes off, it's most likely the inverter cable. If it goes black then it's the Display Data cable.
Score 1
Comments:
Yeah, i can still see the desktop when the light goes off. Everything seems to be pointing at the inverter cable.
Thanks! I will post my results as soon as I get a new inverter cable.
by
Well Mayer, the screen will stay white if the display data cable is faulty or disconnected.
by
Add a comment
Add your answer
Jose A Palacios will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,434
