Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
MacBook beeping differently with different combinations of RAM.
I recently purchased new RAM Chips from Corsair (2x4GB DDR3 1066MHz). When I replaced the old memory (2GB) with the new memory and turned my computer on, the screen didn’t turn on and the MacBook started beeping once every 5 seconds. I read around here that it means that the RAM isn’t detected.
I tried different combinations with the old RAM and the new RAM and I even tried putting every RAM stick at once in every slot. I found out that each one of the new memory sticks works when it’s installed at the top slot only, with the bottom slot either empty or with the old 2GB RAM sticks.
Another weird thing is when I place the new 4GB stick at the bottom slot and the old 2GB stick at the top slot, my MacBook beeps 3 short beeps, 3 long beeps, 3 short beeps. Also, when I place the new 4GB RAM stick at the bottom slot with the top slot empty, the computer doesn’t recognise the RAM, giving me 1 long beep every 5 seconds. Once it even gave me 3 beeps the same length on repeat.
It’s kind of confusing so I’ll put it this way:
4GB RAM on the top, 4GB RAM on the bottom - 1 long beep every 5 seconds
4GB on the top, 2GB on the bottom - works
4GB on the top, empty on the bottom - works
2GB on the top, 4GB on the bottom - 3 short beeps, 3 long beeps, 3 short beeps.
empty on the top, 4GB on the bottom - 1 long beep every 5 seconds.
Any thoughts on what could it be? I don’t think the new RAM is faulty, because each one of them works in the top slot. It seems like the bottom slot cannot handle 4GB of RAM.
1 Comment
I am unsure of what the problem is but you can read up on Mac beep codes at the link below.
https://support.apple.com/en-us/HT202768
by
Add a comment
1 Answer
Most Helpful Answer
Let’s make sure of your exact machine. Please enter your serial number on this link and tell us exactly what you are running:
https://everymac.com/ultimate-mac-lookup...
UPDATE
Sometimes you get a partial failure on a slot where it won’t read a higher value stick but will a lower one. First thing I would do is used some canned air and blow that lower slot out. Visually examine it for any anomalies.
Next, put just one of the 4 GB sticks in the lower slot and loosen the retaining screws on the RAM receptacle a quarter turn each and give it a try. That failing try tightening a quarter of a turn.
Score 3
3 Comments:
MacBook Pro "Core 2 Duo" 2.4 13" Mid-2010.
by
No luck with that. Did that and it gave me the SOS beep at first (3 shot, 3 long, 3 short). After I reset it again it beeped once every 5 seconds. Could it be related to the fact that I also just changed my HDD for an SSD and I installed the HDD in an optibay?
by
When diagnosing a problem it is alway best to do one upgrade at a time and then test. Take it back to the original hard drive and then test the RAM.
by
Add a comment
Add your answer
Davver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 43
