Complete disassembly and installation guides for most iPods, including iPod Original, Mini, Shuffle, Nano, and Touch.
7171 Questions View all
My earbud plug broke off in iPod?
What to do if my earbud plug breaks off inside my ipod.
Add a comment
1 Answer
Chosen Solution
Mark Curry you can try the following. This is an answer from a A headphone piece broke off into the input. in regards to broken of pieces in the jack.You can try and find something a little smaller than your head phone plug and hold your phone horizontal and use some crazy glue to glue it to the piece that is still attached. Make sure of course that you do not get any into the jack. You can also try to use some very small surgical tweezers if you still have enough to get a grip on. Otherwise you may have to replace the jack. Not knowing exactly what ipod you have this could be straight forward or a PITA. Sometimes and I just use this advise carefully, it works if you take a very small screw that is long enough and screw it into the jack.It might catch the broken part and then you can pull it out by the screw head. But be very careful with that since it can split your audio jack and/or break it off. Good Luck.
Score 1
Add a comment
Add your answer
Mark Curry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,093
