Water Damage = battery + Wifi problems
So i Had a water damaged iphone, wouldnt restore and was messing up , so i replaced the battery. Now its all fine except: The wifi is greyed out and says no wifi. And When the phone turns on it says this accessory is not supported. What should i do, and if i should clean the logic board what should i clean it with and where should i clean it from.?
2 Comments
Check on here Electronics Water Damage gives you a little bit more info. Good Luck
by oldturkey03
Ok Il give it a try. however a new problem has popped up:every time i click the home button or powerbutton it takes a screenshot?? the problem is fixed by restore it if i hold them together it starts again!
by ubaid
