Unveiled at the 1290 New York International Auto Show in 2004, the Xterra was redesigned for 2005 on the Nissan F-Alpha platform used by the Frontier, entering showrooms April 2004 for the 2005 model year.
6 Questions View all
Why is my driver’s side window not going up when the controll is pre
Power window does not respond when control pressed on driver’s window. It is stuck in the down position. All other windows work ok. Lock button is in the off position .
Add a comment
1 Answer
Chosen Solution
Hey, Robert. This could be one of 2 issues. Either the switch itself or the window motor. You’ll need to remove the switch and use a multimeter to test the switch. If the switch is not your problem it is probably the motor. Here’s a video of someone taking their passenger door panel off of a ‘06 Xterra, It should be very similar to yours. Good luck and let us know how it goes!
https://www.youtube.com/watch?v=4DP7e7RO...
Score 2
Add a comment
Add your answer
Robert Laney will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 1,498
