My Printer says ink is empty but I have a new one installed.
I have an Selphy CP760 and it continually says that I am out of ink even though I have replaced it 2 times.
Since there is not any answers on this forum yet, I decided to answer it since I found the problem. The problem with this error is that the gear which runs the ink cartridge is missing? I took this device completely aprt and did not find any evidence of that gear anywhere. The motor that runs the cartridge is the smaller of the two.. I looked for a replacement gear for this motor but am unable to locate one. I did use this printer so I know it worked before. So that’s it issue solved sort of..
How do you get to the gears? I took out 3 screws from bottom but can't get the four tiny ones out!
Same here. Mine is a CP510, but I have seen the internals of the 7XX series and they are the same, and I have the same problem (it was working some time ago, now it’s not and when disassembling, I saw the missing gear). I am trying to look for a solution, but I think the best is to get another, or just forget about it.
There is a YouTube with instructions. Nbrc north bawly cp760. The part that is broken is the gear on the small motor and the dimensions are 10T 1.48mm hole. It can be bought from the famous Chinese website.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 4,455
1 Comment
I can not get my selphy 1300 to reg to my phone I had it for a while put it onto tablet but deleted it off tablet now won't register please help
by carol
