Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
iPhone 6s plus dead after change u4500 u2
phone is clean and no water damage , phone show charging but not charging battery , by moltimetre check + connector battery show 0.50 v . i change u2 ic 1610A2 wrong of the other board . phone is off , i buy true ic nomber 1610A3 and change ic but phone is off .power phone by power suply and show 0.06 AP . when connected charger display not showing battery charging ,
Add a comment
1 Answer
Chosen Solution
You’ll need to closely inspect the area around the Tristar IC to insure you haven’t caused any damage to the surrounding components. Also, if you remove Tristar again, check the condition of the pads to insure there is no physical damage.
If that looks good, then start probing the main voltages to insure there aren’t any shorts that were caused by your work.
Score 1
Add a comment
Add your answer
amir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 128
