Repair guides and support for your Sanyo TV.
360 Questions View all
Half the screen has a dark shadow over picture...need help removing it
My Sanyo DP55D44 right side has a dark like shadow over the picture. Can this be removed easily?…help please.
Update (09/19/2018)
Here is what my screen looks like…I want my beautiful screen back…help, please.
Score 3
Add a comment
1 Answer
Chosen Solution
If you could post a picture to confirm the problem, that would be helpful. I suspect that one or more LED strips have failed or that there is a problem with the Tcon board. If you can post pictures of the boards as well, that may help too.
Dan
Score 2
1 Comment:
Further research has revealed that this is a common problem traced to the LED driver board. This board can either be replaced or repaired. The board should have the following markings on it: 40-55E811-DRD2LG
by
Add a comment
Add your answer
Shirley Gaillard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,727
