Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2261 Questions View all
How to know if the logic board is bad or the screen?
I stupidly plugged a water damaged screen into a 100% working logic board. After connecting the water damaged screen to the board I than connected the original working screen and now I have horizontal lines with a black screen. I can still connect to iTunes in recovery mode without the display connected. Did I fry my logic board or did I damage the connector for the display? Thanks for any help.
Add a comment
Chosen Solution
If the original screen is doing this after you plugged in the water damaged screen and it was working properly before, then yes, you most likely have damaged something on the logic board.
A logic board can work even if particular sub-circuits are damaged, it just depends on which ones. Some are critical and upstream and their failure will impeded the device from working. Others, however, are more peripheral, such as cameras and sensors and yes, even the LCD. So when they fail, the compute portion of the logic board can still boot and be otherwise functional (connects to iTunes for example).
If you have already checked the condition of the connector, then the next step is a board-level repair.
Score 2
Add a comment
Most Helpful Answer
Hi if your phone is detected by iTunes then the logic board should still be working fine as your phone wouldn’t even turn on if the logic board was damaged.
You should try cleaning out the display connectors and make sure that you have fitted them correctly as you must press down on both ends and not the middle of the display connectors as it can lead to it bending which can cause permanent damage to the connector
hope this helps with your problem
Lewis
Score 2
3 Comments:
@lewis7681 I did as you recommended and no luck! I checked both of the connectors and looked at every pin to see if there were any miss aligned. And they all looked straight. While hooked up to iTunes the screen changes the line location and sometimes it is just blank or has a little white with lines. See attached image above. Thank you for your help.
by
your welcome you should proceed to check the logic board for any errors
by
The logic board is good I checked it out. I used a working panel and guess what?! It is now working. Thanks again!
by
Add a comment
Add your answer
Barrett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,576
