Possible To Replace Broken Charging Port?
My friend has stood on the charging cable that leads into the laptop and the pin inside the laptop seems to have broken off, so now I cant charge my laptop at all. Is it possible that ifixit?
What is the correct name for the part so I can request and buy it, if possible?
Thanks in advance
Add a comment
1 Answer
Chosen Solution
yes it would be possible. All you have to do is to dis-assemble your laptop and take a look at the main board. The power connector, if I remember right, is solder onto the main board. You may get a replacement from digikey.com or mouser.com. The reason why I can not give you any part number is because it works better when you see the connector. Let me know if you need the service manual, I do have it available. Good Luck
Score 1
Add a comment
Add your answer
Byron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 27
All Time: 10,395
