Computers that generally don't include an integrated display, and are meant to be stationary.
2125 Questions View all
How do I fix a bent USB port
My case has 2 ports on top like most cases and I accidentilly put in my mouse the wrong way around. It managed to push the plastic bit of the usb port a bit forward. My question is if I can bend it back if so do I have to. The port is still functioning fine but I dont want to run any risk of a short circuit.
The case I’m using is a mastercase pro 6
Add a comment
1 Answer
Most Helpful Answer
Hi Joey
Well, I would say it depends.
shutdown and off the computer mains before doing anything.
Of course to reshape and bend it back, you need to assess and check how bad is it. Of course sharing couple of pictures is great.
same for some of my users…….accidentally tugged on the wires and usb socket got damaged.
so on this… you have some options…
  1. if you are able to get the usb socket, you can take out the I/O board on the casing and with some soldering skills, remove and replace it.
  2. Order the replacement usb i/o board from coolermaster or service center / distributor.
  3. check with distributor if they are kind to change for you.
Score 3
Add a comment
Add your answer
Joey Li will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 2,298
