Repair guides and disassembly information for laptops manufactured by ASUS.
2517 Questions View all
Asus VivoBook flip R518uq back panel removal
I have an Asus VivoBook Flip 15 Model r518uq. I would like to know how to get the back panel off in case I have to make repairs or replace/upgrade parts if someone could help me I would appreciate it.
Add a comment
1 Answer
I have Asus R518UA, and if i’m correct they have the same chassis. Back panel is not removable. You must remove top panel in order to get access to motherboard, HDD and battery. You must remove all screws at the bottom of a notebook (one or two could be covered by warranty stickers) and then use something thin (ideally a plastic prying tool, but even something like a credit card, guitar pick, or even plastic ruler should work ) to free the latches that hold a chassis together. After that top panel should came off, but be gentle when you lift it, because keyboard and touchpad wires are pretty short, and it’s easy to rip them. All left to do is disconnect any wire that comes from the panel to the motherboard and you’re in.
Add a comment
Add your answer
Sean McCain will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 402
