DIMM 3,4 proximity sensor indicating high temperature
hi,
I’ve been having high fan’s rpm for a long time.
After installing Macs Fan Control 1.4.11 I’ve realised that the DIMM 3,4 Proximity sensor is showing more than 85º C or more always. Even after a new boot upt.
I have 4x16gb RAM modules installed, but even with jus 2x modules in DIMM 1,2 it is still showing DIMM 3,4 proximity temperature really high.
What is or where is that sensor?
BTW. I tried to reset the SMC, but I’m not sure if I got it (I don’t know how to check if I had success with the reset). The steps I followed where:
Turn off
Unplug it for 15 seconds
Power it again
Turn it on after 5 seconds.
I’ve opened the Mac Pro and I’ve clean everything , even I replaced the thermal paste. Everything is less noisy, but that sensor has high temperature and I think is responsible for this issue.
Is it possible to know what are the threshold values of every sensor that the Mac is using for activating the fans?
A friend of mine who own the same machine seems to have higher threshold than mine because I can see lower rpm with much more CPU temperature.
Thanks
4 Comments
Install this app: TG Pro take a snapshot of the main screen (make sure you get all of the sensors) and paste it here for us to see Adding images to an existing question
by Dan
thanks for your answer.
I've updated my question with the screenshot you told me.
by Hugh
Now carefully swap the memory modules around so the pair in slots 1 & 2 are swapped over with 3 & 4. Did the sensor for 1& 2 jump to the higher temp or did it stay with 3 & 4?
by Dan
It stays with the high temperature with 3&4 even after swapping the dimm modules. Even more, if I just put two dimm modules on 1&2 it is still saying that high temperature on 3&4.
If I reduced that temperature and assign a lower threshold based on cpu or vcpu, dimm 3&4 sensor can reach 95 degrees
by Hugh
