Originally known as "The New iMac" the iMac G4 was created to replace the iMac G3 as Apple's all-in-one desktop computer. The G4 is easily recognizable by its swiveling monitor mounted above the hemispherical computer. Steve Jobs quoted it as being "a design that will last till the next decade."
136 Questions View all
How can I test the power supply?
Will not start up---battery is good--power supply is in 2 sections--
Comments:
Does it do anything? Sounds, lights, smells?
by
I will Check the cord next--unit does not make sounds no smells--like a rock---I have it pulled apart---
by
Add a comment
1 Answer
Chosen Solution
If you have a voltmeter or a multimeter you can plug in the power supply into the wall and probe the other end with a voltmeter. This should at least give you an idea of the thing is alive. I have seen many cases where the AC cord is bad and the actual power brick is fine.
Add a comment
Add your answer
mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,331
