Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
153 Questions View all
Post Display Replacement, what would cause the computer not to boot?
PowerBook G4 Aluminum 17" 22 1-1.67 GHz
Hello,
I just followed the guide to replace the display on the PBG4 17", prior to this replacement the computer was working fine(both on battery and A/C) connected to an external display.
I checked the logic board connector and the keyboard connector, tired re-seating them both, twice. If i pull the battery out and the A/C adapter, then put them both back it the light is amber. I then hit the power button and the light turns green, but nothing happens. It seems clear that the battery is getting charged, which I guess indicates it's not the DC-in?
I'm stumped.
Any suggestions as to what i could have done by accident, would be great.
Comments:
Thanks for the responses and suggestions. After spending a good 2-3 hours checking cables against photos from guides, I'm not sure what I did. I tried the PMU suggestions, with no luck.
Not sure how to jump the logic board, but I probably just better call this a total fail and try to recoup some money for the parts.
by
Add a comment
Chosen Solution
Six hours and no answer. Maybe that's because there is no easy answer. Obviously you have done something wrong. I would take it completely down and rebuild it from the point that you got deepest into the machine. You've missed something or connected something incorrectly.
Score 3
Comments:
Thanks! i think i might have muffed the keyboard cable now that I took the entire thing apart. There is a small rip in it. Is there anyway to boot without keyboard as just a test?
by
jump the contact points on the logic board with an inscription POWER BUTTON written aside of the contact points
by
Add a comment
Hi there...
Thought I'd 'chime-in' with this little thought of remedy.
(After) you've checked that every connector, every screw and everything ELSE is firmly and correctly placed, try this...
***Replace the C-MOS battery.***
I know it might sound too simple, but that's happened to me more often than you'd think!
IF that doesn't work, try a factory re-set of the CMOS pages (revert to factory setting) to see what that does for you.
If that's doesn't help, then there's a possibility that something else may be not connected correctly. Go over everything once more (patience) and I'm sure you'll discover the small error...
Good Luck
P2 of BORG
Comments:
Borg - in the Mac world a cmos battery is refered to as a PRAM battery
by
Thank you...
by
Add a comment
Add your answer
mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 663
