The Kenmore Elite HE3 is a washing machine by Kenmore.
668 Questions View all
pump runs 10 + minutes until it codes out F2
Similar situation: new pump installed. Run any cycle and a small amount of water shoots in then the pump runs 10 + minutes until it codes out F2. Drain line is clear. Tied to pressure sensor? Pressure tube appears to enter back of washer. Can it clog?
1 Comment
a_riddle1 is this the same situation that prompted you to replace the pump? What is the exact model number for your washer?
by
Add a comment
Most Helpful Answer
a_riddle1  you did not tell us if you replaced the pump for the same reason. With a normal F/02 error code for long drain you should get a “Sud” error after 4 minutes and then the F/02 error after 8 minutes. If yours goes right to a F/02 I would take a look at the control unit. The pressure switch is always a posibility. Download the service manual for your washer fro the bottom of this page Kenmore Elite HE3 Washing Machine and run the diagnostics. The same manual will tell you about the pressure switch and how to test it on page 40. Let us know what you find out.
Score 1
Add a comment
Check this guide out, it might help you fix your washer & come to a conclusion.
Add a comment
Add your answer
a_riddle1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 38
