battery not charging after 1st replacement
Hello,
I own a Macbook Pro 13” Retina from Early 2015 that has been troubling me with battery issues. I recently replaced a dead battery (confirmed the need by Apple Genius) using the ifixit.com replacement kit and was doing well for 2-3 weeks until today when I got the same notification that my battery isn’t charging and needs to be replaced.
So far, I have reset SMC and I have re-opened the laptop to remove and replug the battery back in. The AC Adapter is lighting orange and without it plugged to the laptop, it dies. I am confused as to whether the battery is faulty or if there is some sort of disconnect between the AC power and the replacement battery. Also, can this just be fixed if I get another replacement battery?
Any input would be much appreciated. Thanks!
4 Comments
I've forwarded your issue to the IFIXIT Store folks. Given the holiday weekend (Labor Day) they will likely be in touch with you Tuesday next week as the soonest.
by Dan
Thank you for all the input and help!
by kelsey
Did you get the reply? Battery not charging after 1st replacement with the battery kit
by Dan
Yes i did. they reached out to me. thank you
by kelsey
