Replaced Battery, now only runs w/ power adaptor
I just replaced my battery using the repair guide here and did everything properly (as far as I’m aware.) When I went to turn it on, it would not turn on. After I plugged it into the charger it turned back on but showed “Battery not charging” and the power source is adaptor.
I reset the SMU and ran the Apple Hardware test but both indicated no issues. Everything runs fine otherwise and I have not noted anything else wrong. It is running off the charger… which makes me thing that isn’t the issue. I even dis/reconnected the battery part inside the computer just to be sure.
Any ideas on what I should do next or how this has been fixed before? I haven’t found any similar issues on this site after doing the battery replacement.
1 Comment
try to check your battery health by using any app
by Amily Grey
