Mac Air dies only when battery is installed - already reinstalled OS
Macbook Air Mid 2013
The computer randomly freezes (sometimes 3 min, sometimes 1h) but only when the battery is installed. No problems when battery is removed. I had assumed my battery was not good and purchased a new one. To my surprise the issues persists.
I already reinstalled the OS and ran Apple Hardware Diagnostics. I also tried different types of resets.
I noticed that when the battery is installed the computer heats up right when I start it (70 Celsius) and the cools down. I assumed it could be a heat sink problem and thermal paste had to be reapplied but I am discarding this option now.
What could it be guys? Only feezes and shuts down when on battery and I am using a new battery now.
4 Comments
Did you have a liquid spill onto the keyboard/trackpad at some point?
by Dan
Never! the computer is very well kept.
by francoluigi_mendes
What kind of apps do you run? Does the system often get on the warmer side? Also how full is you SSD drive?
by Dan
At the moment about 30gb of 256gb is being used. Since I reinstalled the OS I only have Dropbox and MS Office installed. I only run now Safari.
It gets warm on the left side above the keyboard and on the bottom in the middle close to the screen joint. It gets warm but not extremely hot like if I would be using it for hours non stop.
I'm wondering if when without battery the CPU runs slower (the system feels slower) and therefore it's not overheating. When on battery I turn it on and temperature peaks easily and rapidly to 75+ Celsius.
I think I will try reapplying the thermal paste. I can't think of anything else. Do you have a special paste to recommend? Should I also change to a new heat sink?
Thanks a lot Dan!
