Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
745 Questions View all
Replacing Hard Drive for Erly 2011 MacBook Pro with SSD
Hi,
I am trying to replace the Hard Drive on my Early 2011 MacBook Pro with a Samsung 860 EVO SSD. I have followed the guide and know that the new SSD is working as I have removed the original Hard Drive and the computer works using the SSD through USB.
I bought the 2012 SATA cable. But when I turned my computer on I still got the question mark in the folder error.
However I think I may have damaged the new SATA cable when I was installing it. I have included a picture of the cable and would be obliged if someone with more expertise than me could let me know if I have indeed damaged the cable or perhaps suggest where I am going wrong.
Thanks,
Glen.
Update (08/24/2018)
Sorry images didn’t post
Comments:
I see a few small dents and the remains of the adhesive. What within the limited view here do you think is damaged?
by
Hi Dan,
thank you you for your quick reply. I did what you said and it brought me to internet recovery. It is just stuck on the screen in the photo below.
[image|1528497]
I think the cable may be damaged in the highlighted section. It looks to be broke and I can see what look like copper wires on either side of the break.
[image|1528499]
Thanks,
Glen.
by
Ah! Yes the cable got folded hard and the shield foil got damaged and the inner wires likely got damaged too. Ouch! New cable time.
by
D’oh. Thanks for your help Dan.
by
Add a comment
PC Laptop Batteries
An easy fix for a big power boost.
Shop Now
PC Laptop Batteries
Shop Now
1 Answer
Most Helpful Answer
Put the cable back in with the drive connected. Now this time restart the system and hold the Option Key to set to the Startup Disk manager. Do you see the SSD at this point? If you do select it and the system should boot up. If that indeed works you’ll need to go into the system preferences setting and alter the Startup Disk setting within it.
I do recommend you apply a strip of electricians tape on the uppercase where the cable crosses over as the rough aluminum surface can damage the cable over time. Also don’t bent the folds! You want arcs not sharp corners. The foil wires inside are fragile! Bending them too much can damage them.
Score 2
Add a comment
Add your answer
Glen Shanahan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 138
