No sound from my car audio, when you open/close the left side door
When car audio only plays if you bang the right side door of your car.
guys in the service centre opened it up, checked everything, but unable to figure it out.
2 Comments
Is it needed to replace the whole wiring unit? The possible culprit is may be screw in the door, which happens to touch the wiring of the speaker. How to deal with this???.
by Melvin Joe
If you can remove the speaker or door panel I would think it is just the connection to the speaker. However it could be catching in the section of the door that meets the frame of the car, there is usually a foam pipe that runs into the door, you can see it when the door is open. Try squeezing it with the stereo on and see if it creates the same issue.
by Minus
