Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
1137 Questions View all
How to remove the hard drive to extract data?
My old mac ibook g4 will not turn on, apple says something to do with mother board. I am needing to extract data from that hd to my new mac. thinking about removing hd and putting in a housing to connect it to my new macbook pro? any suggestions?
Add a comment
1 Answer
Chosen Solution
You can use an external enclosure: Firewire ATA Laptop Hard Drive Enclosure
If it's a firewire, you will be able to boot from it. You can't boot from a USB drive.
You can also use an adapter. This will handle ATA & SATA 3.5" & 2.5": http://eshop.macsales.com/item/Newer%20T...
For the correct guide on removing the hard drive please tell us which iBook you have. Here's a guide for the 800MHz 12" iBook G4 12" 800 MHz-1.2 GHz Hard Drive Replacement
Score 2
Comments:
thanks Mayer, my new macbook pro doesn't have the same size firewire port so I am a bit confused ? any ideas ?
by
You can get a firewire 400 to 800 cable or a fire wire 400 to 800 adapter
http://eshop.macsales.com/Search/Search....
by
Add a comment
Add your answer
madge wilson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,461
